TASKalfa 8353ci hole punch not showing up
  • kuby
    • Oct 2007
    • 1414
    Installed a TASKalfa 8353ci and adding a DF-7110 finisher with a PH-7A. How do I get the hole punch unit to show up? I thought it would auto find it?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1901
    Re: TASKalfa 8353ci hole punch not showing up
    Make sure you have it plugged in to the correct place. The connector will reach a couple of different spots.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • kuby
      • Oct 2007
      • 1414
      Yea thanks. The tech had plugged in the one wire into the wrong plug. All is good now.
      • tmaged
        • Oct 2008
        • 1901
        My response was from experience.
        We have had a few recently show up as Japan when installed. They will do 2 hole punch.
        You have to go in and change the country for it.
        Hope that helps !
        -Tony
        www.dtios.com
        • kuby
          • Oct 2007
          • 1414
          Yea had that too. And had to go in service mode and change it.
