KYOCERA ECOSYS M6230 broken gear . How to order 519 ?
  • HOSTAKI
    • May 2019
    • 23
    [Misc] KYOCERA ECOSYS M6230 broken gear . How to order 519 ?
    On a KYOCERA ECOSYS M6230 the customer used non genuine toners and on the CYAN the lever broke . He forced it to release but no luck . He then applied more force, only to cause damage to the 519 gear as shown in the following diagram :
    Parts Catalog > Kyocera > ECOSYS M6230cidn > page 14
    Problem is .. how do I order the specific item, which is not listed under its own P/N and if its for sale as a complete unit which one would that be, as the No 13 --> 302NR02180 "GUIDE TOP RIGHT" comes empty and none of the wanted parts are attached to it?
    Thank you all in advance,
    John
  • dalewb74
    • Feb 2018
    • 1143
    Re: KYOCERA ECOSYS M6230 broken gear . How to order 519 ?
    problem is why don't you sell the customer a new copier after they broke that one?
    • lees
      • Apr 2011
      • 95
      Here is a list of some of the 500 numbers for that page of the manual. Sorry I don't have descriptions for them, but you can get that when you make an order with Kyocera. Hope this helps you and others.
      • HOSTAKI
        • May 2019
        • 23
        where is the list ?? !!
        Thank you for your reply !
        • lees
          • Apr 2011
          • 95
          Sorry about that. When I copied it in, it did not work right. I will try that again.
          504-302NR02520
          505-302HN21450
          515-302NR02440
          516-302NR02470
          517-302NR02510
          518-302NR02700
          519-302NR02820
          520-302NR02480
          521-302NR02450
          • HOSTAKI
            • May 2019
            • 23
            Also this thread is very very helpful to understand whats going on with the 6230
            Kyocera ECOSYS P6230cdn/P6130cdn - Error 7002
            and get also more info on the part number not given directly from the kyocera parts catalog
            520 - 302NR02480/ Joint lever
            518 - 302NR02710/ Joint Shutter
            519 - 302NR02820/ Gear Idle
            kudos to https://www.copytechnet.com/forums/members/kyo_oem.html
