Kyocera Ecosys MFP Error printouts
  • brunot
    • May 2012
    • 148
    [Misc] Kyocera Ecosys MFP Error printouts
    Hello everyone,
    I have a Kyocera Ecosys M6635cidn multi-function printer and scanner. It was working fine. The customer has upgraded to Windows 11, and now whenever it wakes up from sleeping, it prints a 2-line page saying:
    Get /eSCL/ScannerStatus HTTP/1.1
    Host: Localhost
    Uninstalled Printer, reinstalled -- no change
    Updated printer firmware -- no change
    Switched USB cable to another USB port -- no change
    Thank you for your consideration and time.
  • Ropariva
    • 677
    • diedux
      • Jan 2017
      • 124
      To solve this, I would use the access control list on the device, or change the RAW port to something else rather than 9100.
      If the printer is connected to a single PC with only USB, this does not make sense and I don't have an answer.
      BR.
      • ronny2502
        • Mar 2020
        • 79
        Re: Kyocera Ecosys MFP Error printouts
        Hello all,
        have a look at:
        (duplicate inquiry)
        Best regards,
        Ro
        • kuby
          • Oct 2007
          • 1408
          This is the response it got from support.
          Hello and thank you for contacting Kyocera support.
          That isn’t a specific machine failure. I did a search and found some references, you might do the same.
          How to Fix Get /eSCL/ScannerStatus HTTP/1.1 Host: Localhost
          Object moved
