What is a Wise Core Printer?
  • green4go
    • Jan 2022
    • 51
    Happy Holidays everyone
    I am working with IC Link and I see a check box from "Wise Core Printer". I cannot find any information about it. I'm thinking its a generation (controller version or type of controller) of printer/copier, but can't find a good answer. If it is a type of controller? is there a list of models that have them?
    Thanks for the help
    • 23003
    Re: What is a Wise Core Printer?
    The Falcon III was the first WyseCore processing printer, around October 2006. I may be wrong about this, but I believe every Kyocera print engine after that is a WyseCore device.
    Up until then Kyocera devices were certainly multifunctional, but only one function at a time. On a FalconII, if you sent a scan, the scan must complete before you do anything else. The FalconIII was Kyocera's first device to drop the job into memory, then perform the jobs as resources became available.
    I doubt very much that your device is older than October 2006. I'll welcome correction from anybody who knows better. =^..^=
    • green4go
      • Jan 2022
      • 51
      Thanks for the answer. I wish the documentation was a bit more helpful.
      Have a Happy New Year everyone
