taskalfa 5002 scan
  • Gab
    • Aug 2015
    • 677
    taskalfa 5002 scan
    I have installed several scanner setup for this machine . But in one laptop while i follow the exact same procedure i fail and i can not scan.
    Is there any problem because want to scan from laptop?
    Also the host name is LAPTOP-0674U4 IS THERE ANY PROBLEM WITH SIGN "-" ?
    aNY IDEA?
  • Saturn
    • Nov 2023
    • 172
    Re: taskalfa 5002 scan
    Try using the IP address of the laptop instead of the host name. Does this work?
    A "-" (dash) is allowed in the hostname.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • darry1322
      • Oct 2010
      • 817
      aNY IDEA?
      Make sure the laptop network is set to private and not public.
      • OlliK1969
        • Nov 2016
        • 312
        Hi
        Is the scan folder shared?
        Sharing - Advanced Sharing - Permissions ??
        • dalewb74
          • Feb 2018
          • 1167
          look for anti-virus and firewall blocking you.
