4501i machines overtoning or ghosting alot ???
  • CCS
    • 266
    Seems like alot of my 4501i's I still have out there running want to overtone or ghost image.
    I am using all oem toner and supplies, pm kits, etc.
    All routine calibrations and so forth done to no avail.
    Only fix I've found is to replace new drum and dv units, but on machines that already have relatively new drums and dv's, what gives here, any input what to do to prevent overtoning and ghosting?
  • copiertec
    • Jan 2016
    • 2211
    Re: 4501i machines overtoning or ghosting alot ???
    Are you vacuuming out all the waste toner tubes from the developing unit to the fan box on the back of the machine and all the filters related to that area? Most of our over toning issues come from that area not being cleaned out good.
    • CCS
      • 266
      yea, I probably have not accessed the back of some of these machines in a while since some are in tight quarters, will do.Thanks for the reminder, appreciate it.
        • 23009
        I agree entirely, I just want to clarify the terminology: I call those fan ducts, since the fans draw away airborne toner from the developing process. When those ducts become plugged the toner piles up on the bottom lip of the developing unit, and in the registration roller cleaner, leaving smudges on the first page of a set. You can find them completely plugged. Bring your vacuum and be prepared to take apart the back of the machine to do a proper cleaning of the ducts. =^..^=
        • majorjam
          • Jun 2023
          • 6
          Not my favorite model to work on just because of the dusting that naturally happens. When it gets excessive, I replace the developer. Over time, toner will pile up behind the transfer unit as well and get on the registration rollers and cause some print quality issues. Not a bad idea to vacuum behind there as well.
          • copiertec
            • Jan 2016
            • 2211
            Yes, also, remove the transfer belt assembly while your at it and clean really good in there as well as that does build up with toner as well.
            • Scottb
              • Apr 2013
              • 306
              once you've vacuumed everything 302LH94342 seal set probably needs to be replaced as well...that is if you can still order them
