Kyocera P6235cdn problem with Toner residue on lower Fuser roller
  • i-have-fax-problems
    • Mar 2020
    • 105
    Dear colleagues,
    there's a problem with toner residues on the lower fuser roller.
    I had this issue with a black/white machine and you can change the fuser mode from 1 to 2 in the settings.
    This worked.
    Can I do this here too?
  • Saturn
    • Nov 2023
    • 171
    Re: Kyocera P6235cdn problem with Toner residue on lower Fuser roller
    Do you use original or compatible toners?
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
