KM 5052 noise
  • kmtech
    • Sep 2008
    • 125
    KM 5052 noise
    I have a Chirping noise which sounds like its coming from the Drive motor, not sure, i know of the bulletin fix but would like some other input. Machine is KM 5052c
    thanks in advance
    Bill
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1901
    Re: KM 5052 noise
    The most common thing we've seen on this series is a clutch in the feed drive unit squeaking.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • kmtech
      • Sep 2008
      • 125
      Re: KM 5052 noise
      Thanks Tmaged, i will check that.
      Bill
      • Dark Helmet
        • May 2009
        • 867
        Re: KM 5052 noise
        Im new to the Kyocera game but ive seen on that frame 4 things.
        In the side door rear frame side near the top is a little white plastic roller, i think it's a belt tensioner.
        In the LCT trays 3/4 that drive pack has needed oil
        Feed drive pack.
        On the right side of LCT 3/4, the feed roller behind the side door has squeaked and it tends not to squeak until you run the crap out of it. It comes out with 2 screws and 1 connector.
        Do not put oil anywhere near the clutches. I dropped dabs of oil on a M3550 drive pack on all the bushings chasing a squeak and wiped out the clutch. It turned into the Bob Marley. Hes always jammin...
        • kmtech
          • Sep 2008
          • 125
          Re: KM 5052 noise
          Feed drive pack.
          Thanks much, Lawrence, going out today and will check these offerings out.
          Bill
            • 920
            Re: KM 5052 noise
            There is a clutch in the registration roller assy. (part #302RH94090) that will make noise . I believe it only makes the noise when actually making copies and not when in test mode
            • kmtech
              • Sep 2008
              • 125
              Re: KM 5052 noise
              Yes Sir, I pulled the drive for feed and the exit unit, lubed all metal bushings out back together and no more noise! Thanks to all!
              bill
