C1000 on TA 7002i
  • copycart
    • May 2009
    • 97
    C1000 on TA 7002i
    I have this C1000 intermittent code on a 7002i, It says it's bypass lift motor and I do see the lift plate in the up position. Everything mechanical looks fine after taking apart the MPT. Tech support relates it to the Relay PWB, which I can't fine in the parts manual. Any help on this one is very much appreciated. Copier has 300k and was sold brand new about 4 years ago
  • dalewb74
    • Feb 2018
    • 1167
    Re: C1000 on TA 7002i
    and what have you done to try to fix it?
    • copycart
      • May 2009
      • 97
      Sir, I have taken the MPT apart to check sensors, lift motor problem and gears. It acts as if it gets a spike to the lift motor to turn on even with the tray in the upright position, I have also added a surge suppressor.
      • copycart
        • May 2009
        • 97
        Just ordered a new board from Hytec
        • subaro
          • Oct 2010
          • 1274
          What part number were you given ?.
          I would think the relay pwb would not be the problem here, more like the motor itself or the feed pwb which the relay wires are wired into. Or maybe the lift cams that are attached to the lift shaft are cracked. Have not worked on those for a long time and, so I am not familar with the layout. I looked at the parts diagram and schematic to kinda see what is going on.
          to test the motor , top up the mp tray and and do about two copies. If the tray motor is working ok, it would lift the tray. If the tray motor is weak, it may still lift when there is only a few sheets. I had this problem, with a different machine, but the situation was the motor was weak, due to I guess lot of use over a long period.
          • copycart
            • May 2009
            • 97
            302K994200 PARTS PWB JUNCTION ASSY SP
            Kyocera tech support called it a relay board, Thinks it just the paper feed board for the MPT
            • subaro
              • Oct 2010
              • 1274
              It is a relay board. This relay pwb, just collects all the wiring in that area and transfers it to the feed pwb located in the rear of the machine. It has no logic chips on it, so it is just a junction or transfer board.
