Hi, i've set up user codes on this machine, and my customer wants to restrict the amount of copies per user. is this posible in any way???
km-2050 user codes?
from the advanced guide:
Output LimitYou can set the limit of total count of copying and printing.NoteThis item is not displayed if both Copy Restriction and Print Restriction are set to Unable to
use.
1Display the Limit in use screen referring to steps 1 to 7 of Registering a New Account.
2Press the key or the key to select Output
limit.
3Press the Enter key.
4Press the key or the key to select No limit or
Counter limit.
5Press the Enter key. If you have selected Counter limit, the Counter limit Default
Value screen is displayed. Proceed to the next step.
Copy:
Able to use
Unable to use
Printer
Limit in use:
End
Copy
: Able use
: Able use
Printer:
Able to use
Unable to use
Output limit
Limit in use:
Copy
Printer
: No limit
: Able use
: Able use
Output limit
No limit
Counter limit
