km-2050 user codes?
  • cmpelser
    • Jan 2008
    • 173
    km-2050 user codes?
    Hi, i've set up user codes on this machine, and my customer wants to restrict the amount of copies per user. is this posible in any way???
  • LNorris
    • Sep 2008
    • 645
    from the advanced guide:
    Output Limit
    You can set the limit of total count of copying and printing.
    Note
    This item is not displayed if both Copy Restriction and Print Restriction are set to Unable to
    use
    1
    Display the Limit in use screen referring to steps 1 to 7 of Registering a New Account.
    2
    Press the �� key or the �� key to select Output
    limit
    3
    Press the Enter key.
    4
    Press the �� key or the �� key to select No limit or
    Counter limit
    5
    Press the Enter key. If you have selected Counter limit, the Counter limit Default
    Value
    screen is displayed. Proceed to the next step.
    Copy:
    Able to use
    Unable to use
    Printer
    Limit in use:
    End
    Copy
    : Able use
    : Able use
    Printer:
    Able to use
    Unable to use
    Output limit
    Limit in use:
    Copy
    Printer
    : No limit
    : Able use
    : Able use
    Output limit
    No limit
    Counter limit
