TaskAlfa 250ci and SMTP Server input via Control Panel
  • scoobysteve
    • Jun 2008
    • 163
    Hi All,
    Just wondering if anyone can confirm if you can set the SMTP server details via the control panel?
    The reason is that the client has no access to the web interface (Command Centre) - GPO policy blockout. thanks.
    • 22999
    Sorry, No...
    For the TASKalfa you'll have to crossover to a laptop. Then enter Command Center from your browser.
    There were more Send options in the System Menu of the Voyager. At least you could set the SMTP address. =^..^=
    • aragul
      • Dec 2007
      • 128
      I couldn't find anything through the panel except enabling/disabling SMTP. I'm pretty sure the only way to set that up is through the Command Center.
      • scoobysteve
        • Jun 2008
        • 163
        hi guys,
        thanks for the replies... its a bit of bummer i guess.. have to get in touch with client IT to sort out..
