km 3050
  • habik
    • 2013
    #16
    Re: km 3050
    Originally posted by Kidaver
    I coded a machine out with this 3 times yesterday trying to trick the front door to watch how paper was feeding in cassette one. The front door has 2 switches it must hit. There is a white button switch that senses if the door is closed or not and just a little to the left is a metal push down switch that senses.....well I'm not exactly sure what it senses but if you don't press this one when the other is pressed it seems it will throw this code on you.
    The 2nd switch is disconnecting power to the mainframe, only logics are ON.
    Firmwares HERE
