km 3050
  • Iman
    • Jul 2008
    • 57
    km 3050
    Hi all I am having a problem with an error code c5300-cleaning lamp error.So far I have checked and changed the engine pcb and main controller pcb.I have also changed the drum unit and did a continuity check on the block connecter and the lamps.Also I have removed the main charge and transfer charger corona units and updated the firmware.Has anybody had or heard of this problem.
    • 23009
    Well, it looks as though you've covered all the logical choices, and all the more remote possibilities.
    The only additional thing I can think of to do is to pin-out the harness from the drum unit connector to the engine PWB.
    As I was reading through your post, mentally I had jumped ahead to "I wonder if he has a shorting primary...", but I can see that you've got that covered.
    • Sayen's
      • 20
      had same problem and went thru all the boards, power supply, drum, cleaning lamp etc, came down to the left side door safety switch wasn't making constant contact. Leveled machine and sorter on a 3/4 piece of plywood and haven't had any more problems. the sorter wasn't putting pressure on the switch and actually the side door wasn't seating all the time.
      • Iman
        • Jul 2008
        • 57
        Thanks for the replys guys.It turned out to be a bad connection on the front door switch even though it wasnt showing a door open problem.Thanks for the pointer Sayen
        • KyoceraChris
          • Jun 2009
          • 112
          the newest firmware has taken care of that afew times for my techs..
          you gunna eat yo corn bread?!?
          • eboucher
            • Oct 2008
            • 7
            Which switch did you replace? The interlock switch or the little white switch?
            • Iman
              • Jul 2008
              • 57
              It was the inter-lock switch that was causing me the problem
              • HaTePlOw WoRc
                Re: km 3050
                This may sound really wierd but check the magnet on the inside of the front cover to see if it has popped out. I reseated the magnet into the door on a 3050 that was stuck to the metal and it got rid of the error code. Hope this helps
                • habik
                  • 2013
                  Re: km 3050
                  It may sound silly but you know that there is a difference in drums between 3050 and 40-5050 right? Just a thought. Hope your machine is leveled and it is functioning by now .
                  Firmwares HERE
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Re: km 3050
                    What's really silly is that the original post was in '09 and you guys are still responding to it.
                    • Eric1968
                      • 2458
                      Re: km 3050
                      LOL!!!
                      • habik
                        • 2013
                        Re: km 3050
                        Repetition is The Mother of Wisdom
                        Firmwares HERE
                        • Gar the pilot
                          Re: km 3050
                          yes old tread but still a problem in field as I am working on this today. More info helps even if old posting.
                          Thanks Gar the pilot
                          • habik
                            • 2013
                            Re: km 3050
                            DRUM for KM3050 in case is replaced from a different PM kit like for 4050 or 5050 as they not the same
                            or
                            Front Door Interlocking Switch (probably loose magnet) I use 2 cable ties to secure the magnet in place see attached pics.
                            or actually faulty Interlocking switch on front door or side door.
                            Firmwares HERE
                            • Kidaver
                              Ghoulscout
                              • Apr 2011
                              • 912
                              Re: km 3050
                              I coded a machine out with this 3 times yesterday trying to trick the front door to watch how paper was feeding in cassette one. The front door has 2 switches it must hit. There is a white button switch that senses if the door is closed or not and just a little to the left is a metal push down switch that senses.....well I'm not exactly sure what it senses but if you don't press this one when the other is pressed it seems it will throw this code on you.
                              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
