Kyocera Falcon 3 machine problems 3050/4050/5050
  • nillane
    I am having huge problems with these machines, especialy slow LCD screen. has anyone encountered it as well or other problems on these Falcon 3 machines. Machine also only comes with 512MB memory not enough is it????
  • texchar555
    Senior Production Tech
    • Mar 2007
    • 142
    nillane, kyo came out with the newest update march 1st. Hey, its not the best thing yet. but it is going to increase the speed up by 15 secs. Wow!
    . we are going through the same thing. Cust not very happy . good luck.
    • pat
      • Mar 2007
      • 16
      Yes the speed of the display is a disaster everytime you get the disc on your screen the machine is actually writing to its HDD. Can't wait for the software update.
      • Mark B
        • Jul 2006
        • 153
        It is going to take alot more than a software update to speed these things up. I do not thing they will increase the speed.
        • Duke
          • Sep 2005
          • 19
          Kyocera Falcon 3 machines
          the update only marginally increased the speed by maybe 3 seconds, do not expect a miracle on this one........Duke
          • monstott
            that is a common complaint about these machines so far... the memory is sufficient, the problem is that every movement is accessing the HDD, much like a PC, so it is a lot slower than what most customers are going to be used to using. We have one in our shop here as a demo, but have not really been pushing them much, mainly due to the response speed. Hoping for a firmware update soon that may speed things up.
            • stevee104
              • Mar 2007
              • 214
              install the optional 512 memory
              • nillane
                Any suggestions as to where to get the memory...some guy suggested memory experts, where did you get your upgrade..I heard Kyocera wants 300 Bucks for it in the USA. Memory Experts International when I called them said it was only $75 with a lifetime warranty? Let me know if you have any other suppliers.
                • kyoceradude
                  The Great Gazoo
                  • Aug 2006
                  • 442
                  I heard from our Tech Rep on Wednesday that there will be two waves of firmware upgrades. One will be before the Kickoff in Vegas, in April, with the second to follow. Main things addressed are the speed of display and also moving things around on the display to make them less confusing. I'll let you know.
                  My mission here on Earth is to help all you Dum-Dums!
                  • kyoceradude
                    The Great Gazoo
                    • Aug 2006
                    • 442
                    New Firmware
                    New firmware should be posted next week. Rep says will speed up the op panel. We'll seeeeeeee....
                    • nillane
                      Lets keep our fingers crossed.
                      • JSC
                        Gimp
                        • Dec 2006
                        • 618
                        Just heard the firmware has been delayed a week or 2 from Japan
                        The gene pool could use a little chlorine.
                        • nillane
                          Someone let me know when that upgrade is available. Also I did upgrade the machine with the 512MB memory and it has helped the panel alot. Also it has opened up the 600 x 600 dpi full color scanning option.
                          Not a bad option
                          • dinotech
                            Blah, blah, blah. I'll believe it when I see it....
                            • 10871087
                              • Jan 2005
                              • 1062
                              Just got an email from KMAconnect and the new firmware and tech bulletin are out. I guess I will be in the showroom on Monday to see what the results are.
