KM-4530 Z fold
  • stevee104
    • Mar 2007
    • 214
    KM-4530 Z fold
    Have a 4530 that z fold only on duplex, runs single sides find have change out the duplexer, transport section and transfer corona but no luck .
  • scanman
    • 15
    Is the Z fold occurring at the registration roller? If so, there is a separate adjustment in U51 for duplex copying. You might want to check that. Really need more info than (It is z folding when duplexing)
    • stevee104
      • Mar 2007
      • 214
      have try the 51 adjustments to no luck it is making about a third of a copy and will fold down into the tansfer corona only on the second side out.
      • KyoceraChris
        • Jun 2009
        • 112
        if u51 dosent work you might want to try the reg clutch...
        you gunna eat yo corn bread?!?
        • scanman
          • 15
          Is paper curl an issue or maybe separation? Don't remember if there is a separate transfer voltage for duplex, might check and see.
          • kyoceradude
            The Great Gazoo
            • Aug 2006
            • 442
            Have you replaced the reg and pre-reg clutches???
            My mission here on Earth is to help all you Dum-Dums!
            • chexin51
              • Aug 2008
              • 37
              possible solutions
              Problem: intermittent jams every 7 copies with z fold before reg roller
              Solution: try spaying LPS cleaner in Deck Drive clutch pack Part #50 page 42 parts list
              2AC06240 Clutch Paper Feed x 2 suspect
              if no change clutches #28 and #29 are suspect page 42 parts list
              replace 2BC27630 CLUTCH 34 FEED
              2AC06230 CLUTCH REG
              and gears that are driven by motor if mileage over 1.5 million
              Problem: intermittent jams in duplex
              Solution: case #1: clean every rubber roller in duplex and clean all clutches in duplex
              also worn rollers in deck conveying can cause jams in duplex only when #4 cass used
              replace 2BC07390 RIGHT ROLLER DECK CONV
              2BC07400 LEFT ROLLER DECK CONV
              2AC06240 CLUTCH PF ( both mag clutches )
              also rebuild #4 paper feed
              case #2: SOLENOID STOPPER 18327130 becomes magnetized and duplex jams at
              the white rollers intermittently occur
              • demitry
                aw
                so sad to know that but i am also one of you guys....
                • tech07
                  • Aug 2008
                  • 410
                  duplex z fold
                  I actually fixed one today.. It was the registration clutch...Didn't have new one, so I diassembled clutch, cleaned inside and out with q tip and alchohol and cleaned clutch shaft... 1 sided ok.....2 sided z folded...fixed
                  • demitry
                    oh
                    hmmmm....!
