km 3040 c-9000
  • toner89
    • Dec 2006
    • 19
    km 3040 c-9000
    hello this machine send me this code i check the voltages its ok ,but when the customer lift the dp to make copies direct on the glass apears c9000 if its the board on dp i have the manual parts but doesnt have the dp part number any help.
    i run sumulation 906 and still same problem
  • Lbcoaster
    • 43
    Were you able to find a solution for this problem? I am having the same problem...
    Steve
    @ Lbcoaster@aol.com
    • n25an
      • Jul 2008
      • 1030
      I think its the dp
      Disconnect the dp and test... if you get the error its the dp...
      Sad To Say I Don't Have a Life
      I do this stuff on the weekends too
      • Lbcoaster
        • 43
        If you disconnect the DP(Doc Feeder?) shouldn't the problem go away if its the DP?
        thanks for the help, the feeling is there's a short some place.... just a thought I'm still got my problem
        • n25an
          • Jul 2008
          • 1030
          if the problem goes away... then its the document processor...
          you can either replace the document processor board and/or the harness... I would do both...
          • tech07
            • Aug 2008
            • 409
            Re: km 3040 c-9000
            Replace the cable that goes from the copier to the DP..I have done this...There is a technical bulliten
              • 22929
              Re: km 3040 c-9000
              You do realize that this thread is three years old? I certainly hope it's been resolved in some way. =^..^=
              • Lbcoaster
                • 43
                Re: km 3040 c-9000
                Yes, had to replace the main logic pcb....
                • Lbcoaster
                  • 43
                  Re: km 3040 c-9000
                  you're welcome, never know when someone may need the info....
