kyocera mita km2530 image cycle
  • ronsulit
    • Jun 2009
    • 13
    please help, when i turn on my kyocera mita km 2530 "image cycle" will appear in the screen. please help
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Replace the toner.... and make sure it is the correct toner for the machine. Use OEM toner not any generic.
    My mission here on Earth is to help all you Dum-Dums!
    • youngblood
      copier janitor...=)
      • 18
      kyocera dude has it... if it isn't this than there is a problem with the toner sensor or drive motor, kickin any codes randomly?? whats the copy count?
        • 22930
        That's it. As the toner cartridge gets you'll see "image cycle" more and more often until you get the Add Toner indication.
        Sure, you can change a setting to get the Add Toner indication at 10% remaining, before the "image cycle" messages, but isn't that a huge waste of toner?
        • ronsulit
          • Jun 2009
          • 13
          the copy count is 166039, i am new in this machine. i dont know what to do...
          • Craigdumass
            • Jun 2009
            • 61
            Adding Toner
            Sometimes there is a belt behind the mainboard that becomes worn very badly and begins to slip it runs from the bypass up to the toner add system. It is not very fun to replace.
            • madhavanr
              • Mar 2009
              • 15
              if u are slim , u can easily replace the belt with in 15 to 30 min.
              if u are fat or over weight , my friend ......... it will take take more than a hour to replace the toner drive belt . every month i am wasting one hour for this belt replacement. so i am trying to loss my weight.
