scan to smb with a km2560
  • luis8832
    • Dec 2008
    • 250
    trying to set up scan to smb with a km2560/i got the xp pro pc's to scan with no issue at all. The vista pc's which are running business i keep on getting a connect error. The unit gives me a 2101 send error code. I connected directly with a crossover cable and the scanning worked. Why would the xp's work on the network and vista's won't. Any advice?
  • cboucher
    • Aug 2025
    Go to Control Panel\Network and Sharing Center and make sure "Network discovery" and "File sharing" are both turned ON.
    • luis8832
      • Dec 2008
      • 250
      yes they were both checked off. like i said i connected with a crossover and i got it to work.
      • luis8832
        • Dec 2008
        • 250
        Originally posted by cboucher
        Go to Control PanelNetwork and Sharing Center and make sure "Network discovery" and "File sharing" are both turned ON.
        i connected with a crossover and i got it to work also the network discovery and file sharing are turned on.
        • cboucher
          • Aug 2025
          The only other thing I can think of is right now is checking the permissions under both the "sharing" and "security" tabs to make sure the user you specified is allowed write permission. I would just give full control for testing purposes and see if it solves your issue.
          • luis8832
            • Dec 2008
            • 250
            so why would it work with a crossover? no issues at all. scanned three times no issue.
            • cboucher
              • Aug 2025
              A crossover to one of the same Vista machines that wouldn't work before or a crossover to your laptop?
              • luis8832
                • Dec 2008
                • 250
                to the vista pc that was giving me the error on the network. my laptop has xp pro it would have worked.
                • cboucher
                  • Aug 2025
                  Bummer. If you were just having the issue with the one Vista PC I would say you might have a duplicate IP address on the network or a bad network cable or something to that effect. But since you say it's happening with all the Vista PCs, it would appear to me to be a setting like the one I described earlier that doesn't exist in XP. Good luck...
                  • Craigdumass
                    • Jun 2009
                    • 61
                    SMB on a Windows Vista Machine
                    Go to Windows Security on Windows vista and under exceptions allow for the port being used for SMB scanning to go through.
                    • luis8832
                      • Dec 2008
                      • 250
                      i gave it the exception i keep on getting a connect error going back on monday morning to try again
                      • Mr Spock
                        Vulcan Inventor of Death
                        • Aug 2006
                        • 2064
                        Check and make sure the Vista machines and the copier are on the same workgroup. I have had this issue on some Toshiba's.
