KM3050 error!!!
  • pete!
    • 10
    KM3050 error!!!
    Hi everyone
    Client got this km3050 ..
    when scanning she sometime get the error cfb37....
    what's the solution for this problem...
    I have format the hdd... update the firmware....
    anyone had this problem before???
    lmk asap..
    thanks
    Pete
  • Craigdumass
    • Jun 2009
    • 61
    Are you scanning to Email if so set your email size limit to 0
    • pete!
      • 10
      No scanning to smb (folder)
      seem like a problem with the operation panel...and the dimm in the operation panel
      • Craigdumass
        • Jun 2009
        • 61
        I can remember there was a problem with the Dimm earlier with the machine where they wanted you to take out and reseat the dimms, but I thought all of this was taken care of with a later version of firmware.
        • pete!
          • 10
          KM3050
          I flash the firmware again.... maybe it was a bad flash
          we'll see from there....
          I will keep this update! ..until a good solution is found..
          thanks
          • etsmultan
            • Apr 2007
            • 131
            u have 2 check frim ware
            • Morlock49
              • Mar 2009
              • 166
              There was a problem with the gold plating on the dimm cards for the op panel and the main pwb. I had to change the dimm cards on every 3050 we had. there is a bulletin out now with the new Dimm part numbers
              Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
              • texchar555
                Senior Production Tech
                • Mar 2007
                • 142
                I looked at one today and the other tech replaced dims on the main bd and the control panel. The dims were the white not gold or yellow. Still having the problem. removed the control panel reset the dems and connectors. I installed the panel and guess what? Black screen hmm , so I messed with the wires and noticed that if you set panel low the wires are pulled down away from the machine. I reset the wires and presto its working. In other words, I think instead of boards and dimms its back to the wires,tyraps and the wires just being streatched from the manufacture. remember the 6030/8030 with the laser code and all it was , was the tyraps being so tight it caused codes? well
                  • 23009
                  I have seen the problem you describe, texchar, and it is caused by the white ribbon cable to the op panel rubbing up against the plastic op panel covers in the rear. I usually try to put a gentle arc into the ribbon cable so it doesn't press so hard against the cover. The symptoms that I got were not CFxxx codes though. I got a frozen or blank display, and if you move the accessibility lever it will start to work.
                  Having said all that, I don't think that is the poblem that pete is having.
                  • pete!
                    • 10
                    km350
                    Still not working!!!!!!!!!!!!
                    i had the dimm taken out ..clean them reseat them...
                    still not working!!!
                    • SwampYankee
                      • Jul 2010
                      • 20
                      Bad op panel dimm or bad memory dimm. I lean towards memory dimm, myself, had plenty of oddball issues cause by flaky memory.
                      • pete!
                        • 10
                        will change the dimms on op panel..next week and I will let you..if it works..
                        thanks
                        • goose1127
                          CFB37 Error
                          Realizing this is a way old thread, I have the same issue with a KM3060, the CFB37 error Did you ever get resolution on this?
