Kyocera Prescribe Command
  • sggarge
    • Jun 2009
    • 19
    Dear all, I have KM-2050, KM-4050 MFPs, Please help me how I can write Prescribe Commands to the Printers. I have IC-Link Version 3.2, I Brough Compact Flash Card (1GB) for writing Prescribe. But I dont know how to operate the commands to the printer. I wanted to write a command (Macro) for CCPY which can help me to do following job
    I wanted to print individual print from two different cassette. I mean to say that I have special custom made software and I wanted to print single page on two different type of pages like a carbon copy (i.e. Red color paper is in Cassette1 & White color paper is in cassette2) How could i send print to printer so that printer will automatically print same job on different color paper. I have to print mass quantum to print like this.
    I will be glad if anyone send me a complete procedure as I am doing such work first time.
    • 30423
    commands
    you will not need the cf card
    you will create multi part form tray 1 and then tray 2
    you will have ccpy on.prn file and a ccpy off.prn file save under my doc
    using the kx driver pcl xl under advance tab prologue button
    add the on file as the start
    add the off file as the end
    its easy but alot of steps
    good luck
    • copytechman
      • Nov 2008
      • 953
      My bad your correct, the cf card is used if your using your own "overlays" on the forms.. It has been a while thats for sure... theres a bit more to it than that but I don't recall the specifics @ this time..
      Regards!
      A.
      • sggarge
        • Jun 2009
        • 19
        Thanx BSM
        good luck
        it works ! Thank you very much
        • PANG
          • 104
          good luck
          How about this if i want to print 2nd tray is letter head copy A4 paper and 1st tray is normal A4 paper. It is working if i follow thisway ?
          • sggarge
            • Jun 2009
            • 19
            yes sure man
            • PANG
              • 104
              Originally posted by sggarge
              yes sure man
              Hi ! sorry to disturd , i copy everything to show to IT man, he seem to dont know how to write this command u dont mind can u write it in datailed so that i can show to my IT guy. THANKs IN ADVAND>
