KM-2050 Paper Pickup problem
  • sggarge
    • Jun 2009
    • 19
    I have KM-2050 and after 600000 copies Tray-2 was unable to pick up paper, So I have changed a pick up roller of tray1 & tray 2. But still Tray-2 is unable to pick up the paper, What would I have to check? (Tray 1 is working fine)
  • LNorris
    • Sep 2008
    • 645
    pull out the tray two feed section, see if there is paper torn in it.
      • 30294
      feeding
      has the feed tires and sep roller ever been change? If not replace them.
      • Cirrus
        • May 2008
        • 43
        I have seen the feed clutch go out on these a couple of times. Matter of fact the last one I ordered had definitely been modified from the original.
        • sggarge
          • Jun 2009
          • 19
          I have solve the problem. Problem is with the separation tyres and clutch. I have change sepration tyres and aligned the gears along with clutch. and problem is solved thank you for your feed back
