cs-6030 scan problem
  • Dave10
    • Jul 2008
    • 197
    I have a very unusual problem here. It's a little involved so forgive me. We have a cs-6030 with a scan system in the field. When the customer scans documents to e-mail (which is the only way they scan), the image shifts to the left about .25 inch. This is scanning from the document feeder. When COPYING from the doc feeder, the image is fine. I have checked all the scan defaults, and found nothing out of the ordinary. If I set the defaults to full-page scan and auto-center, I can get the whole image, but it shrinks to 93%. The clients are engineers and need some pages to be in scale, so this is out. It does it when scanning 8.5-inch lead or 11-inch lead, and a cs-3050 on the same network and scanning to the same e-mail accounts are fine. We brought the firmware for the machine and the scan card up to date.
    All other copies and prints are fine, but if you try to send the scanned image back to ANY printer, it will print off-center.
    Anyone seen this before? HELP!
    • 23009
    Are the originals true 8 1/2" x 11" letter or perhaps more like A4...
    We have a automotive supplier that gets engineering specs from Germany. They had a strangely intermittent "Load Paper" indication that would not present when I was present. Just by accident I happened to notice a stack of originals that did not stack so nicely.
      • 30284
      scan
      copier are fine?
      standard for all adjustments is the bypass are the images ok in bypass
      also check status pages and check oem setting for adf
      how are scans from glass not adf?
      • Dave10
        • Jul 2008
        • 197
        Originals are true 8.5x11. I know this because the scanned image does almost look like A4 or some different size, so we checked. Copies from everywhere are okay. There is a 5000 sheet deck which is a little off because it chanbes every time someone moves it, but all internal copies are fine and prints are fine.
          • 30284
          scan
          check the size the adf and off the thinks it is?
          does the machine see it as a 8 1/2 by 11 or other size?
