KM-6030, KM-8030
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    #16
    km-8030
    I've got 3 or 4 of these on my area and i've set them all to 1 million on the pm cycle. The heater roller goes at about 300k but after replacing it it lasts untill the million. Main problems i have are operator errors. Right hand side door sensors being pulled off - customer slams the door from the top, not in the middle hence it knocks the sensors out of its position(giving permanent jam), pick off bar(fuser unit) not being shut down properly, transfere section damage (customer) and various other damage to the machines. All in all a fantastic bit of kit and i prefere this to a ricoh 2105 which has a lower service cycle,its faster and a bitch to work on when the toner pipe goes tits up!
    Incontinentia Buttocks
    • geoff_bell
      #17
      i've recently got a job in a reprographics department with one of these machines (coupled with a DF-650 finisher).
      is there anywhere i can find a list of jam codes and what sensors might trip them?
      • Artsmith
        #18
        Great Box
        I've been running one of these for over two years now. It's the best b/w machine I've ever had. I put around 40,000 copies a month on it, and I go six months between services -- and it's usually something minor.
        I also find that its a pretty intuitive machine; good controls -- it doesn't take a rocket scientist to run it. I'd recommend it to anyone.
        • kingpd@businessprints.net
          • 921
          #19
          Re: KM-6030, KM-8030
          NEC put their name on these...love them! A lot of off lease deals with good prices are coming around now, with low counts of 1,2,3 or so hundred thousand...awesome!
          • juan_khu
            #20
            Re: "00" jam KM6030
            Originally posted by Tommyc
            Hey Guys,
            Have any of you seen "00" jam code on a KM6030. Technician replaced duplex switchback roller and now this jam code is permanently on machine...
            Thanks,
            Tom.
            Now I have 00 jam code on my 6030. anyone know how to solve this?
            thanks.
            juan
              • 23007
              #21
              Re: "00" jam KM6030
              thanks.
              juan
              A J00 jam condition results when the machine is powered Off/On, and a sensor remains actuated at power On. It could be any sensor. You'll have to check the sensors in simulation U031 to determine which one it is.
              Some common ones to be dislodged are FSW2, FSW3, FSW4, and ESW. =^..^=
              • JustManuals
                • Jan 2006
                • 9838
                #22
                Paul@justmanuals.com
