5050 wierdness!!
  • Jimbo1
    • Mar 2008
    • 845
    5050 wierdness!!
    You put the test target on the glass and it looks fine. You print the status page and it looks washed out.
    Any ideas?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • 23010
    EcoPrint? We have a salesman that is forever turning this On, then bitching about not being able to read the prints.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Any ideas?
      I have one that does the same, copy ok, prints ok, but any internal prints ie status or loged data pages all washed out........and ecoprint is turned off
      The gene pool could use a little chlorine.
      • Tebow83
        • May 2009
        • 92
        have about 4 that do the exact same. spent an age swapping boards, doors, transfers etc to no avail.
        At the end of the say one its prints ok and copies ok, it will do rightly
        • Santander
          • May 2009
          • 768
          Since the status page appears washed out your looking at an image formation problem. But because a copy looks acceptable, I would believe someone has been playing around with the Sim settings.
          My first plan of action would be to go through each Sim setting and set it back to the default listed in the manual. You can then start troubleshooting from there (if you need to). I can't tell you how many times I have been called in on a problem only to find out that a setting(s) was changed to do a "quick fix" rather than replace a componet and it never gets logged on the machine report.
