c2352 taskalfa
  • texchar555
    Senior Production Tech
    • Mar 2007
    • 142
    c2352 taskalfa
    c2352 code on a 400ci giving one of our techs a headache. He called support and ask for help and all he got was replace some boards. color cleaning motor at fault
    • 23008
    Not on a Saturn, but on a Voyager the cleaning units are driven by the paper conveying motor. On the Voyager, if the bevel gears that drive the waste toner portion of the toner cartridge start to skip, then toner rocks will start to collect in the waste toner collectors, and in the cleaning units.
    I haven't had a very close look at the waste toner drive on the Saturn (I know its really different), but that is where I'd start. Then I'd check for a seizing color cleaning unit. =^..^=
    • texchar555
      • Mar 2007
      • 142
      thanks blackcat for the info I will inform the tech and I will research the info too. I will let you know.
      • texchar555
        • Mar 2007
        • 142
        motor was going out . fixed
        • jockey
          • Aug 2008
          • 52
          Re: c2352 taskalfa
          I have a 300ci throwing the same code, took the back off turned on the power switch all the motors turn, could it still be one of the motors? I noticed Texchar555 said the motor was "going out"
          • Tonerkiller
            • Oct 2012
            • 668
            Re: c2352 taskalfa
            Yes one of the cleaning motors is bad. It looks like it is working, but it is actually catching drive from the drum.
