KM 6030 and KM 8030
  • tcypy1961
    • 773
    KM 6030 and KM 8030
    Good machines???
  • dyodyo
    • 28
    yes! why?
      • 22999
      Solid, high volume workhorses.
      • tcypy1961
        • 773
        I service both Ricoh and Kyocera copiers and I have the opportunity to get either a KM 6030 or 8030. I did a side by side between the KM 8030 and the Ricoh 2075 and they appear to fairly equal. What one has the other may not and vice versa. The 8030 has a little over a million copies and the 6030 under 500,000 I believe. I already have a Ricoh 1075 and I really don't want to go down in speed. I'm not sure if it would be a wise investment to get a 8030 with a million plus copies. I use these high speed copiers for short term rentals.
          • 22999
          1M copies is just two short PM cycles. It's a baby!
          I've only worked on a few AF-1075's but I seem to recall issues with the toner suction tubes, and the semi useless large capacity tray that doesn't want to slide over the stack of 4 reams of paper. True or False?
          • 10871087
            • Jan 2005
            • 1143
            They are very good machines, do the full PM at 500k cycles and these machines will perform well.
