KM-5050 With noise in PF-750
  • xcopy
    • Mar 2009
    • 57
    It makes a loud gear or drive belt skipping noise when it feeds from the right deck over to the left. All the clutches have holders and i have swopped clutches arround as they are the same ones. But still noisey.
    Any ideas?
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    There are many posts on this problem. The small clips on the frame of the feed assy break off causing the feed assy to lift up, causing gear mesh noise. If you look at the left feed pulley assy, rear side you will see the broken clip. We drill a hole from bottom and secure assy to plastic frame with a small countersunk screw.
    My mission here on Earth is to help all you Dum-Dums!
      • 23009
      Ditto.
