copystar cs-4050
  • wulffservice
    Service Team ******
    • Jul 2009
    • 29
    copystar cs-4050
    Need help on a code for a copystar cs-4050 CFB30 Thanks
  • Craigdumass
    • Jun 2009
    • 61
    Did you call technical support on this?
    • Hutcheson
      • 15
      Updating the firmware will usually resolve that problem.
        • 30238
        code
        whats the code?
        • wulffservice
          Service Team ******
          • Jul 2009
          • 29
          Thanks for the assistance
          Appreciate the responses and we determined it was a communication problem with the controller. Found connectors unplugged on controller PCB and unit came back to life only to code out with a similar code. Thanks again....
            • 23008
            cfB30 is a main PWB system error. The few times I've seen it were situations of firmware incompatibility. The firmware DIMM that I transferred to the other machine did not have a firmware level compatible with the rest of the machine firmware. All I had to do do was flash it. =^..^=
            • moussmouss
              fax codes,disregard.
