hole punch error KM3530
  • repeatcopiers
    • Sep 2008
    • 591
    Have a KM3530 in the field that keeps saying Empty hole punch, but it is empty....can anyone tell me what else to check? Also they say it won't hole punch during printing but will for copying, was working before but not now. Any ideas?
    • 23008
    I'd start out with a U906 partial reset. If the source of the error is intermittent it may not re-occur.
    • LNorris
      • Sep 2008
      • 645
      isnt there a sim to clear the hole punch count as well? dont have a manual in front of me
      • n25an
        • Jul 2008
        • 1030
        hole punch problem
        if no one else has suggested it then check the sensor behind the waste hole punch basket...
        Sad To Say I Don't Have a Life
        I do this stuff on the weekends too
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          I agree. It's my understanding that the partition switch is what resets the counter. make sure the copier is on when you remove the punch waste bottle to empty it. If the partition switch is bypassed (or jury rigged) it won't reset the counter. (partition switch is the bottle in switch)
          My mission here on Earth is to help all you Dum-Dums!
          • n25an
            • Jul 2008
            • 1030
            bypassing switch
            a practice that often leaves the switch flagged.... yep that really sounds like the culprit..
            • n25an
              • Jul 2008
              • 1030
              hole punch printing problem
              lets fix the hole punching printing problem...
              interesting... go into the driver properties... device settings... and then make sure that the finisher is displayed you may have to auto configure it and then exit out or select the finisher and add the option by checking boxes and exit out...
              in whatever case... the function must be available and selected for the hole punch to work... so 3000 sheet finisher should be selected and then hole punching becomes available and you select that and then apply and exit out...
              now try printing something and hole punching should be available...
