I have a bank with a proprietary software. They said they can only use an HP PCL 5e printer. I convinced them that the Kyocera FS-4020dn would work for them.
After installing everything worked fine except for two documents they routinely print. It is a form they generate whenever they open new accounts.
On the Kyocera the third line of text from the bottom prints on top of the fourth line from the bottom, leaving the third line blank.
HP prints fine, Kyocera messes up. I tried using the KX driver in PCL5e mode as well as the Uni PCL 5e driver. I also tried changing the print processor to the same print processor used in the HP printers. They all yielded the same results. The emulation on the machine was set to KPDL (auto) and I did not think any other emulation would work.
Any ideas
Any ideas
