FS-C5030
  • LNorris
    • Sep 2008
    • 645
    FS-C5030
    rebuilt a 5030 with mk. now the Magenta is giving a 0953 error (magenta led), i have swapped drums with the Cyan and Yellow with the same error. i'm leaning towards the ledrly board....but i wanted to check with you guys first to see if you have seen this and what the resolution may have been.
    thanks
  • LNorris
    • Sep 2008
    • 645
    ok, the magenta is showing correctly and no errors. however the print has streaks running thru it, which is one of the things i was fighting before.
    i've attached (even tho its in b/w you can see the light streaks).
      • 23010
      You've probably already cleaned the LED heads several times. When you swap the cyan drum unit with the magenta drum unit, does the streak pattern in the patches switch places? I suspect not. I think that its a developing issue.
      • LNorris
        • Sep 2008
        • 645
        yeah, cleaned the leds. i swapped all 3 color drums and issue remains. i am beginning to think its the ledrly pwb, but not sure...so frustrating...lol
