SMB and TaskAlfa
  • spiderman76
    • Mar 2009
    • 59
    SMB and TaskAlfa
    Hi,
    I am facing problem using the SMB option in TaskAlfa 250ci to scan files to my folder in Mac OS X.5
    Anyone face or have solution to this problem? Error 2101 .
    There is a procedure to run SMB protocol to Os X 10.4 ?????
  • jneezy2008
    Software/IT
    • Mar 2009
    • 72
    According to the manual for the TASKalfa series, error 2101 is: The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
    With that, I would try:
    Let the MFP DHCP. It will hopefully grab all the necessary IP settings(subnet, gateway, domain name, DNS, etc) automatically(this also reduces user input error).
    Try accessing the Mac using another computer(PC or Mac).
    Use the IP address of the Mac vs its hostname.
    Replace the Ethernet cable connecting the MFP to the network.
    The snozberries taste like snozberries!!
    • assistenza
      Anjin
      • Mar 2008
      • 20
      Enable windows sharing...
      Enable windows sharing...in Mac is very impartant for use smb...;-)
      • compsos
        • Nov 2008
        • 22
        We have seen what may be similar. 2 sites both with 300ci machines both with Linux File Servers. One can scan a store a document to the server the other fails with error 1103. Which translates to invalid username or password.
        A TCP dump reveals that the 300ci is sending in the right username (accepted by the server) and password (also accepted) but the 300ci then tries to write a test file beginning with . (a full stop) this is rejected. Is there a way to stop the test file or modify it from being a hidden file?
        • ExOceMan
          • Sep 2009
          • 63
          Why not use FTP you should be able to scan without any issues. OS X has built in ftp server. SMB sharing on OS X is kinda shabby at best.
          • n25an
            • Jul 2008
            • 1030
            smb scan to mac problem
            I ran across this problem before... check this link
            Sad To Say I Don't Have a Life
            I do this stuff on the weekends too
            • Moti M.
              • Dec 2008
              • 8
              Dont work so hard, on MAC only Scan to Mail can work.
              Configure the SMTP and go home...
              • n25an
                • Jul 2008
                • 1030
                scan to smtp not only option for mac scanning
                Its not true that this is the only option but if you are pressed for time... scan to smtp or scan to mail might be a heck of a lot faster if you are not mac proficient...
                • jneezy2008
                  Software/IT
                  • Mar 2009
                  • 72
                  Setting up scanning to the document box or to a flash drive would be best. Setting up scan to email can be a headache in itself especially if the customer is using a third party to host their email.
                  • n25an
                    • Jul 2008
                    • 1030
                    thats a good idea
                    good idea if customer is tech savvy... for most of my customers I try to keep their interaction with the machine as simple as possible... any more and I will end up shooting myself in the foot...
                    • psraji
                      • 6
                      Scan to SMB (MAC)
                      Hi, Try the following steps to resolve the scan to smb error 2102.
                      1.From the MAC desktop find the utility menu.
                      2.click the terminal/telnet sub menu to get terminal window .
                      3.Type hostanme to find the MAC book name.
                      4.Type ping space and identified the hostname.
                      5.Now you have the ip address, just enter the ip addres in the command center instead of hostname.
                      hope this helps.
                        • 23009
                        The problem that I had was getting the correct mapping to the scan folder. It took me many many tries to find something that worked. Sorry I can't be more specific. I don't consider myself Mac competent. I'm still stumbling through with Macs.
