I posted a thread on this once before yet I have a few more questions. This customer called for toner I installed the toner and they called back saying the copier kept stopping saying to add toner then go into image cycle which I know is normal. The toner cartridge was from Katun. I had an earlier problem with a Katun toner cartridge for this model copier with another customer. They called say the copier was making a terrible noise which was coming from the toner cartridge. I was able to free up the toner cartridge gears and so far so good. I would like to say the same for the copier I'm talking about. The first trip I came to the conclusion that the develping unit and drum unit needed replacing. After installing and executing sim130 the copier ran and the toner sensor # never changed. The time(sec) # climbed to 701 before I stopped the process and removed and reset both the drum and dev. units. I then ran sim 150. I don't understand what the book is saying in relation to what I see on the copiers display with this sim. The dev. sensor and the disposal tank blocks are white all others arer blue. When I check my other copiers all blocks are blue except the disposal tank sensor. If the dev. sensor is my problem where is it located??? If it's in the developing unit then it must be a board problem??? The Dev. Sensor block in sim 150 stays white with either dev. unit installed. When I first arrived the copier was in image cycle and there was a click---click noise being made which I believe is coming from either the toner cartridge or the toner cartridge drive assy. Any thoughts on all this would be greatly appreciated.
THANKS!!!
THANKS!!!
