KM-4050 Touch Screen
  • Absurd
    Just a brick in the wall
    • Oct 2007
    • 118
    I have a customer that says the display will randomly go crazy moving the image up so you cant see the ready to copy or quantities and has a blank spot at the bottom. anyone else had this happen? I dont really want to order the almost $700 dollar lcd just to try.
    Southern Duplicating of Mississippi
    PSN: DrAbsurd (if you know you know)
    "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
  • Jimbo1
    • Mar 2008
    • 845
    I don't know how old the firmware is but you can always try flashing it.
    Or sim 906 but those things were really slow and stuff till about the second or third generation of firmware.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
      • 22999
      Check out this post:
      http://www.copytechnet.com/forums/ky...t-problem.html
      It's probably the ribbon cable to the panel. =^..^=
      • 10871087
        • Jan 2005
        • 1062
        That's a new problem to me, I would always recommend flashing the firmware first, then spend the bucks on the part.
