I replaced Dev.and the drum. the copier worked good for short while then it start damping the dev on one end of the dev unit and that end is inside of the machine, the toner or devoloper will be droped in trans cw and trans cw unit and it will not fused.
I checked Dev unit structure it self no fault found.
What is the idea for this?
Thanks for any help.
