Taskalfa 300ci firmware
  • Realtech
    • Oct 2009
    • 103
    I try to perform firmware update of taskalfa 300ci the machine won't boot on the memory stick.
    • 23010
    Can you be more specific? Exactly what happens when you try to load firmware? =^..^=
    • n25an
      • Jul 2008
      • 1030
      possibilities
      1. bad memory stick... go test it...
      2. you unpacked the firmware into a folder and placed that folder on the memory stick... firmware has to be placed directly on the stick... no folders... straight first level...
      3. you have a bad main board...
      most likely culpritt... is #2
      Sad To Say I Don't Have a Life
      I do this stuff on the weekends too
      • Realtech
        • Oct 2009
        • 103
        Thank you so much I did't unpack the firmware. Thanks again.
