Macbook Pro will not connect to Copystar 2550
  • troyrecreation
    • Aug 2025
    I have a Macbook Pro running the latest version of OS X v10.6.1.
    In our office we have a Copystar (Kyocera Mita) CS-2550 on a network.
    Down the hall we have a Windows XP machine that connects to the CS-2550, and in settings I have found it connects via TCP/IP, with an IP address something like 192.68.##.##
    When I first got my Apple in February 2009 I was able to connect to this network copier/printer. In July I had to reformat this hard drive and reinstall OS X, then recently installed Snow Leopard. Not until last week did I try to reconnect to the CS-2550.
    I went to the Copystar site and downloaded Kyocera Mita OSX 10.4 & 10.5 installer v 1.0.
    Is this the correct file to download and install?
    Is there another file I should also download and install?
    Is Snow Leopard, 10.6.1 not compatible with Copystar CS-2550?
    I installed the file and in System Preferences / Print & Fax / Open Print Queue / it reads..... "The printer software was installed incorrectly. Please reinstall the printer's software or contact the manufacture for assistance."
    I know that my Mac saw the printer, because during Printer Setup it found "Kyocera Mita CS-2550 (KPDL) without me having to type that in.
    Please help if you can.
    Thank you,
    Dan
  • n25an
    • Jul 2008
    • 1030
    this might work
    Thank you,
    Dan
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • troyrecreation
      Generic Postscript Printer fixes problem
      Whatever I had set incorrectly, I do not know, but in Print Queue, I was able to select Generic Postscript Printer as the printer driver, and it now works great.
      Thanks for the previous answer that was posted earlier as well.
      • n25an
        • Jul 2008
        • 1030
        quick reply...
        that will only select tray one... but if that works for you... great...
