any info?
taskalfa 248 codes
TASKalfa CS-250ci, 300ci, 400ci, 500ci
CF248
Process Manager: SYS_PRCM_ERR_FACTOR_PRN_PROC_DOWN (printer process down).
Turn power Off/On.1) Upgrade firmware to v. 3.06 or newer.
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Anyone else still getting this code? I have a customer printing a power point documents and it gives cf248 on 2 out of 40 pages only when doing in color on the TA500ci. When done in B/W no problem or when done on their Xerox it works. Customer also has TA400ci with exact same code. Firmware is at latest 9.01. Print Driver is latest as well. Have also set security to low on machine but no joy. It is almost like there is a security setting in power point that causes just these 2 pages to code.IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ CertificationsComment
That was my thought, too. Try PCL XL in the driver. Leave the printer emulation at Auto. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Update firmware to 9.0. If you read the notes you will see many entries that address CF248.My mission here on Earth is to help all you Dum-Dums!Comment
