KM-1650 problem
  • Jayship
    • Aug 2025
    KM-1650 problem
    I have a KM-1650 in the field with a problem. When copying from the document processor, and only from the document processor, there is a line about 1 inch wide down the center of the page (vertically) that is paler/lighter than the rest.
    Since it doesn't appear from the contact glass, it has me a bit confused.
    I have cleaned all glass and mirrors, shading plate, etc...and replacing the DP changed nothing...any ideas?
    Any help would be appreciated.
    Thanks!
  • Zackuth
    • Aug 2009
    • 448
    I had this problem on a 2550, what I was told to do by one of the Kyocera tech reps was to clean the mirrors with water, as some of the grease used and ozone are only water soluable. I cleaned the mirror with water then rubbing alcohol and the problem went away.
    If at first you don't succeed, redefine success
      • 23009
      The light areas that you describe are usually caused by dirty areas of the white reference.
      You say you cleaned the shading plate. Are you sure its clean?
      • Jayship
        Guess I will try cleaning everything again...
        Does the fact that it only does it from the DP give you any clue as to what I should focus on?
        Thanks.
