Is there a way to back up the address book? I see something in the service mode about it, but when I hit the start key it does nothing. Can someone give me a walk threw?
KM 3232 address book
Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
sknoops
sknoops
So the answer to your original question is :
you should download and install KM Scanner Address Editor and save your addresses to disk with this software. You can download it from the KM-site.
About the scanner not working : Did you check cables, ip-settings, ... to see if there is a network problem? Does it give a code when it stops working?Comment
I haven't seen a code when it stops working. The only thing I've seen is the amber light next to the scan button lite and when you hit the scan button it just beeps.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
sknoops
Yes, software is on the public site, under Application :
KYOCERA MITA | ServiceWorld | Download Center - laserprinter, printer, copier, multifunctionals#
Could also be a defecrtive scanner module ... still strange it does not give any error message.Comment
Could also be a defecrtive scanner module ... still strange it does not give any error message.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
I agree with Sknoops. If using "Reset disabled function mode" gets it working, you have a defective Scanner NIC board. Have you checked the C-codes? Specifically C0250. Changing the HDD won't buy you anything, unless all the customer does is scan to the HDD. Before changing an HDD I would try to reformat it.Comment
I agree with Sknoops. If using "Reset disabled function mode" gets it working, you have a defective Scanner NIC board. Have you checked the C-codes? Specifically C0250. Changing the HDD won't buy you anything, unless all the customer does is scan to the HDD. Before changing an HDD I would try to reformat it.It's got at least 20 addresses in it.
