FS-1128MFP
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1907
    FS-1128MFP
    Not really sure what is going on ??? I seem to recall playing around when we got our first 1128MFP in to make sure it could scan to a folder & save the address etc. I THOUGHT I remembered it having inbound routing going to email or network folder. I went to install one at a customers yesterday & cannot find it anywhere. There hasn't been a firmware update that I can see, so I don't think it was taken away. Any ideas or just start hitting the sauce early for Thanksgiving ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • aragul
    • Dec 2007
    • 128
    It's just like the 500ci. Login to the Command Center with admin00. The Address Book is under the Basic section. SMTP setup is under Advanced.
    But I'd go with an early Thanksgiving.
    • tmaged
      • Oct 2008
      • 1907
      Thanks for the reply Aragul. I have the SMTP server & all that set. It will scan to email fine. Are the inbound routing settings in the address book ?
      Hope that helps !
      -Tony
      www.dtios.com
      • aragul
        • Dec 2007
        • 128
        What do you mean by inbound routing?
        • tmaged
          • Oct 2008
          • 1907
          I've set it up on Sharp & Toshiba's so that incoming faxes get routed to a folder or email. I thought I remembered seeing it on the 1128MFP. They're on backorder so we don't have any on our showroom floor.
          Hope that helps !
          -Tony
          www.dtios.com
          • aragul
            • Dec 2007
            • 128
            I missed the part about faxing.
            There's supposed to be some way to do fax forwarding from the Command Center, but I don't have an 1128 nearby to play with. You can set it up from the panel through System Menu -> Fax -> Reception -> Forward Settings. Just turn Forwarding on and then give it a destination. You can choose something from the address book or type it in separately.
            Page 4-16 in the 1128 Fax manual describes all of the options.
            • tmaged
              • Oct 2008
              • 1907
              THAT'S IT !!!!
              That's what I was looking for. I kept searching for "routing" in all the manuals. Sharp calls it inbound routing & Toshiba calls it offramp routing.
              I appreciate the help.
              Hope that helps !
              -Tony
              www.dtios.com
