Kyocera Mita DC 3060 Drawer Error
  • DWML
    • May 2025
    Receiving a "Drawer inoperable" error display... copier will only use the bypass tray.... it does not notice any other paper tray? Any suggestions or known resets?
    WML
  • aodtech
    • 194
    Make sure there are no obstructions around the cassette and run sim 96.
    • Scott
      • 189
      sim 906
      I think it is 906
      • montana
        • Aug 2008
        • 393
        hi...why don"t you check the paper cassette lifting mechanism?...maybe theres wrong with the motor or the gears...thanks
        • aodtech
          • 194
          906 is for the digital machines. Maintenance mode in the analogs only have 2 digits.
          • Jules Winfield
            • Jul 2009
            • 821
            Pull out the drawers and check behind them for small scraps of paper stuck in the connectors at the rear of the drawers. Sim 96 should do a "Reset disable function" on this machine. Check both the connector on the drawer itself and the connector it plugs into inside the copier.
            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
            • DWML
              I ran sim 96 and machine comes up with C251 error? any suggestions?
              • DWML
                I ran the sim 96 and machine came back with check drawer and the C251 error. Any additional suggestions? Thanks
                • DWML
                  I checked around drawers and ran the sim 96 display said check drawer and then displayed C251 error. Any additional suggestions?
                  • aragul
                    • Dec 2007
                    • 128
                    C251 = Drawer 2 lift motor problem
                    Either lifting is bad or it doesn't detect the lifted paper. Could be bad motor, bad switch, broken lift mechanism, bad connection to switch, etc.
                    • Jules Winfield
                      • Jul 2009
                      • 821
                      Try switching the lift motor with the one for the other drawer and see if the problem follows the motor. Also try swapping switches, feed units, etc... to narrow down the culprit.
