Mixed size printing on KM copiers
  • ExOceMan
    • Sep 2009
    • 63
    I have some clients that would like to print .pdf docs that have multiple sizes in them. From what I have seen in working with the TaskAlfa series of KM machines they do not support this feature. Has anyone else encountered this and came up with a solution? Additionally, I believe you can send from applications such as Word and have it work correctly. Is this a limitation of their emulated PS3? Please advise.
    Thanks!
  • aodtech
    • 194
    I have a customer that is printing pdf to an FS-1128MFP that contains both letter and legal and it works. So I assume that it'll work in the larger boxes.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      This may be really old news, but very old versions of Acrobat Reader (I'm assuming Acrobat, as well) could not print mixed sizes in the same file.
      I think that changed with version 6, but I don't remember for sure. I know, that's really old, but some people are still running the old stuff.
      The bottom line is that it was an application problem, and not a printer or driver problem.
      I don't think that was ever an issue with Word.
      • ExOceMan
        • Sep 2009
        • 63
        I wish it was an issue like an older software package, but they have all of the latest Acrobat versions/driver/firmware and this issue persists. From what I have read the way the machine deals with sheet size is that the first page determines how the rest of the pdf is handled. Seems to be a pretty limited way to print pdf. Nobody from Kyo has had any workarounds either.
        Thanks for the responses!
          • 30475
          Pdf
          did you try changing pcl 5e or kdpl driver?
          ran into this on a Oki box pcl resolved the problem
          • Jules Winfield
            • Jul 2009
            • 821
            Ever try the "Print as Image" setting?
            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
            • ExOceMan
              • Sep 2009
              • 63
              I have used both the KX driver set to KPDL, and also have used print as image. It happens at the machine as well if you were to print from a USB drive. In my previous experience with copiers that can process PDF they don't ignore the size.
