Copystar 2550 What could they be doing
  • tech07
    • Aug 2008
    • 409
    #16
    2550
    I definitely understand....3 different copiers..same location..same symptom...It's not oroginating with machines....it's external coming in...that's why I would go straight to the wall first...This is a true story.. I had a canon copier once that would indicate adf jams for no apparent reason. No bad parts..decent paper.,etc. Well, after about a month of frustration, I was at this copier and it jammed. Suddenly, I realized that about the same time, a worker with a two way radio passed by close to the copier. Could it BE? I asked him to come closer to the copier and talk on it while I ran multiple copies...Sure enough..When workers came through close to the copier while using their walkie talkies the radio frequency caused an adf glitch.. Unreal, but true..We tested it multiple times...Problem solved ......Look for outside influences.....Wall voltage especially....
    • Warnock
      • Dec 2006
      • 50
      #17
      2550 Shift
      I am assuming that during printing, this never happens. Check for off size width papers. Some accounting firms use a4 or b-something paper. Look out for an intermittent paper size in the mix. I know this is obvious, but I always go that route first if I am not present. I had one account bursting off size paper and mixing with letter size. The only other thing that I can think of is the cable for the ADF. Out of the box problem with the interface cable.
      Programmers don't die, they gosub without return...
      • Frank L
        • 30
        #18
        copystar 2550
        Warnock, they do not use it as a printer, only use 8 1/2 X 11 paper. New ADF's Three different used machines that work fine out of there office. Thanks
        • Warnock
          • Dec 2006
          • 50
          #19
          2550 Shift
          Okay, check for a pattern in the building. It is possible that during certain hours of the day, only a particular piece of equipment is running that will cause intermittent problems during that time. Could be garbage compactor at 4pm everyday, or lamination machine in the morning only. If you don't see anything, see if you can get a line-recorder to record AC throughout the day for spikes etc.
          • Frank L
            • 30
            #20
            copystar 2550
            Yes that is what i am trying to do narrowing it down to something like this or what tech 07 said checking the wall for a voltage across the neutral and ground. thanks Frank
            • Tech59
              • May 2009
              • 18
              #21
              Originally posted by Frank L
              I have a customer that majority of there copying is through the ADF Intermittently it will move the image on the page 2 or 3 inches maybe more when sending copies through the ADF. Doesn't happen all the time might send two pages, both will move, for example name Cusick will be at the beginning of there header It will move text on the page where you will see the K and all other text moved over towards the front side of the machine. It is not centerline adjustment. Sending the page short side in first 8/12 way. Again most of there copying through the adf so on the glass don't know if has ever done this. i have changed engine boards, logic, lastest firmware. I also brought in a loaner 1650 it also did this, this has been going on for 9 months.So okay brought in another machine 2550 with a brand new adf on it guess what , did it again. I even payed for a dedicated line, no help. And again did it twice in a weeks time.Have no idea what they could be doing , it is not like they have never used a copier before.In the mean time both loaners that I have brought them I have sold and they are working fine. Could it be a microwave a refrigerator or is the place just haunted? I do not know what to do. Out of ideas. Thanks Frank
              You might want to Check the Roller od the Paper Cassette trays. if the Pick-up Roller or Feed Roller r worn then it would cause this problem as i had happen before, this problem for me was very intermitent and found that 1st paper Cassette's rollers were worn. Replace all three Rollers (Pick-Up, Feed & Sep Roller) and problem solved.
              • Frank L
                • 30
                #22
                copystar 2550
                Tech59 it is not lead edge and it is three different machines. Thanks
                • tech07
                  • Aug 2008
                  • 409
                  #23
                  2550
                  How did those outlet voltages read??
                  • Frank L
                    • 30
                    #24
                    copystar 2550
                    There electrian didn't get there yet, if that was a copier tech, customer would be screamin. Although they have been geat on this issue, again trying to convince them it is not the copier isn't easy. I will let you know as soon as he shows up. Thanks Frank
                    • tech07
                      • Aug 2008
                      • 409
                      #25
                      2550
                      Hey man.. do you have a volt meter?? check the readings at the outlet for the copier yourself...then go some where else in the building, check an outlet there and see if there are any differences,,, in the past i have literally moved a machine to another room for a few days to prove...
                      • Frank L
                        • 30
                        #26
                        copystar 2550
                        tech07 I have done that, moved the machine to two different area's in the office different outlets, had no luck. Machines still acted up with the same problem. Thanks Frank
                        • chexin51
                          • Aug 2008
                          • 37
                          #27
                          Perform a load test
                          Three different machines - same problem - voltage problem probable.
                          Note: Make sure the firmware is updated on machines.
                          You don't need an electrician to diagnose a wall AC voltage problem but you do have to know how to use a multimeter.
                          In Standby Mode:
                          check the polarity in the 3 hole wall socket
                          Hot to Neutral - not less than 114VAC
                          Hot to GND - not less than 114VAC
                          Neutral to GND - not more than .5 VAC
                          While copying ( the load test ):
                          check Hot to Neutral - the voltage should NEVER drop below 110 VAC
                          you must use a high quality digital multimeter to be able to catch and
                          fluctuations or any analog meter ( the needle moves instantly )
                          Try to find out if the problem occurs mostly at one time of the day which
                          might indicate other equipement on the same line stealing the voltage.
                          A dedicated AC line is highly recommended for any digital copier to avoid just this same type of problem which can be difficult to resolve.
                          • Frank L
                            • 30
                            #28
                            copystar 2550
                            Thanks for the reply , I do know how to use a multimeter, As in the other posts , the machine is on a dedicated line which was installed, because i thought that would solve the problem, but did not . As far as firmware 3 machines doing the same think unlikely firmware, but it was checked to see if it was the lastest version and was. Also I feel better if a electrian do this as he is going to check the surronding area outside, and also might have a voltage analyzer to test the line throughout the day. Thanks for the reply Frank.
                              • 23008
                              #29
                              Don't be so certain that an electrician will do a more thorough job than you. He may know how to analyze the power, but I have encountered very few electricians willing to do so without much cajouling.
                              How many times have you told a customer about a dirty phone line, and the phone company comes back with "But I can hear you just fine?" Your ear may not be the best tool to diagnose a phone line.
                              All I can say is Good Luck. =^..^=
                              • ebm
                                • Apr 2007
                                • 183
                                #30
                                Can you post image of problem? Is the copy shifting front to rear, or lead to trail? Is it magnifying or reducing?
                                I did not see any other posters mention a modification to the DP-410 for electrical noise reduction. Not sure if it applies here, but at this point it can't hurt to look into it.
                                Good luck!
