copystar 2550
Like in previous posts the image shifts from rear to front for example The heading Cusick on the left margin about a inch in you will only see the ick and actually moves about 2 or so inches. from the back to the front cutting off everything on that side and moving the back edge towards the front 2 or so inches. And does this twice a week sometimes twice a day and no certain time either. Again there has been 3 different machines installed. The machine worked fine for the first 7 months then this start happening, then changed engine, logic board, firmware checked. Put in a 1650 same thing put in a refurbed 2550 with a brand new ADF no change. Moved the machine to different areas in the office put a dedicated line in. Still same problem. Going to have a electrian there with me to check voltages and ground issues neutral to ground. Thanks Frank
