km 5050
  • rbell12
    • Aug 2006
    • 83
    km 5050
    we are considering picking these up through a leasing co. just looking for some input on reliability and maintenance issues. tia rb12
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    buying from a leasing company is a lottery unless you know what the history is. I know from previous experience that when m/c's are being stored for return to the leasing company for whatever reason parts are removed and faulty or suspect parts are put back onto the m/c being given back to the leasing company.
    regarding the km-5050, firmware upto date or the lcd is so slow it drives you mad, pm due at 500k so its a drum, dev unit (optional) paper feed on feed statons/doc feeder and the fuser unit. I find these quite a reliable m/c for a b/w. Al depends on what the mtr reading is and if you trust it.
    Incontinentia Buttocks
    • aabarnes1
      • Mar 2009
      • 620
      We have 35 of these machines under the Utax label cd1250, they a really good trouble free boxes apart from maybe the fusing units burning out the press rollers, we look after them too. You're right to advise on checking the history though.
      Grant me the serenity to accept the things I cannot change.
      • Jules Winfield
        • Jul 2009
        • 821
        Lease returns are a gamble even if you are given a history. As stated before, some less scrupulous dealers will use lease returns as free parts machines and of course, say nothing about it to the leasing companies. The only history the leasing company is aware of is the one the dealer gives them...
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
          • 23008
          It's probably the most reliable 50cpm box I've seen in 20 years. It's better than the Canon NP6650, Canon NP6050, Mita DC5585, Sharp AR-M550N, Ricoh AF550 (and all of these others are great boxes, just obsolete). =^..^=
          • Scorotron Wizard
            • 28
            Best machine I have ever worked on (25 Years), had one that went to 500k service interval with no calls at all
            But its true if the machines have been in a copier wharehouse for any length of time then some parts are likely to have been swapped.
            The Wizard
            To the Pessimist the glass is half empty
            To the Optimist the glass is half full
            To the copier engineer...
            The wrong glass has been supplied, it should be 50% smaller Haha
