CS8030 hard drive
  • netad1
    CS8030 hard drive
    Our lease is up and I need to ship the machine out of state, but need to clean off the hard drive first. Is there a quick and easy way to do this?
    • 23010
    Just re-format it. Run U024. Don't forget to make note of the Destination (U265: 02 for Kyocera, 66 for Copystar). Damn, there are quite a few things lost, see below:
    Enable LDAP: 10871087, 508, Start, ON, Start, Stop
    Set Destination: 265, Start, 66, Start, Stop.
    Set Paper Size Large Capacity Tray: 208, Start, Side Feeder, select correct paper size, Start, Stop, 001, Start
    Re-enter Printer IP: Printer, Printer Menu, Interface, TCP/IP, Change, DHCP to OFF, Bootp to OFF, enter IP address, enter Subnet Mask, enter Gateway.
    Enable Corporate address book: System Menu, Scanner Basic, Corporate Address Book, Change to ON, enter IP address of LDAP Converter Utility (currently 172.24.1.157).
    Re-enter Scanner Settings via Web Interface.
    Create One User: System Menu, Scanner Default, Register, set #001 email as Department@copytechnet.com , set Display name as Department Name, Complete Entering key.
    Turn off Display Sender Screen: System Menu, Functional Default Setting, Selection Of Sender (users), Change, set to ON.
    Set Output Tray for Copy:Set Output Tray for Printer:Set Scan to Email default file type: System Menu, Scanner Default, Functional Default Setting, Scan File Type, change to PDF.
    This will do the trick. =^..^=
    • RCR
      • 11
      Hy netad 1
      this is a simply way that you can use:
      First:
      Sim U000 stamp the maintenance mode.
      Then execute this simulation to reset the machine:
      Sim U020; 021 ; 022
      Sim U024
      then you can insert the main data by using the stamp of the Sim U000 previously saved.
