Somebody knows how to reset the admin password from the command center. The default has to be admin00 but somebody or somehow it has been change ? Please help..
I m newbie with this printer and please if someone can explain how to reset password in few steps?
I tried this command Resets account code admin password.
!R! ACNT "REST";EXIT; but it didnt helped me!
I use KM view and when i send this command i get back message "authetication failed".
So my question is how to reset password on these printers if i forgot??
I've got the same problem now!!!
my customer has about 150 users... custom boxes set up and also job accounting etc. etc....
the last thing I want is to loose all of those settings.
also all the "finely tuned" service settings I've made in simulation mode.........
Is there a way to reset just the command centre password??? (for sure)
I can't remember exactly how I did it once but you need to go into system menu on the machine. Select accounting . Input the default code ie : Password = 3000 Username = 3000. Somewhere in there is the option to turn the User & Password off for command centre which defaults command centre back to admin00.
Good luck.
did anyone solve this problem? i have the same problem with a few TaskAlfa models
I've try with u021 and other codes.
and the accounting options, now i'm triying taking off the cmos battery on the printer's mother board.
