Can the Task Alpha series use the Scanner File Utility?
  • jammnn
    I have a customer that wants to use the scanner file utility on a Task Alpha 300ci . If anyone has information on how to set this up please let me know.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    I believe you should be able to. The scanner file utility is basically an FTP server on the workstation. I would think as long as you're using the correct port etc. it should work by setting up a destination in the Address book & having the settings under the FTP section. I've never tried it so I could be wrong. We haven't been a Kyocera dealer real long so I don't have a lot of experience with the SFU.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
